メインコンテンツにスキップ
The Ematic FunTab 2 is a 7" Quad-Core 8GB kid-friendly tablet. It comes pre-installed with a variety of educational games, a parental control dashboard, a front facing camera, a 2 megapixel back facing camera, and other productivity apps.
16回答 すべてを表示
Charging port burned out
I bought my daugter an ematics funtab not even4 months ago and im thinking the charging port broke on it already, it wont charge anymore so we cant use it.. im trying to see where and how much it would be to send it in to get it fixed... if someone could help me thank you
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Anne Strawn since this is a relative new device I would suggest that you contact the place where you purchased it from and see if it is covered under warranty. If not, it might be a bit tricky since this is not a very common tablet. You can try and check the port by using this guide Ematic FunTab 2 Motherboard Replacement to get to it. Check the solder joints to make sure they are still properly attached. Take plenty of pictures and post those with your question so we can see what you see and help you a bit more if needed. Use this guide iFixitでの質問に画像を追加する方法 for that.
iFixitの画像
ガイド
難易度:
とても簡単
2 - 5 minutes
Ematic FunTab2 Motherboardの画像
ガイド
難易度:
中レベル
1 hour
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Anne Strawn さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 12
過去 30 日: 13
今までの合計 117
