メインコンテンツにスキップ
Repair guides and support for your LG TV.
1342回答 すべてを表示
Tv is flickering when watching cable or Netflix. menu screen okay
My LG tv 55UF6800 is flickering when watching cable TV or Netflix. When LG menu screen is being used, the menu portion will not flicker. Can you please give me advice on how to fix this problem?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
3 件のコメント
Thanks for replying. It happens during all inputs and I also tried a different hdmi cable.
さんによる
It happens on my PC too. Display works normal when HDMI is attached and I can see both screens without a flicker. As soon as I play Netflix video, display flickers
さんによる
Yep me too.. blacks flicker in large vertical blocks
さんによる
コメントを追加
2件の回答
ベストアンサー
@raytorres519 sounds like a Main board issue. Check to see if the flickering happens on all inputs. Check Coax HDMI Compostie etc.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Hey OT, you're on fire today :>). Leave some for the rest of the community ;>). I can't vote your answers anymore or it will be wasted.
さんによる
@refectio no worries about votes. Going to take a break and fix my chainsaw ;-) Got some trees to trim so now your turn to keep those answers coming LOL
さんによる
Chainsaw...let me guess why...still lots of cleanup required I guess.
As for questions, not much on the iPhone front today.
さんによる
Yeah got a couple of more trees that need to come down. Starting with some more repairs this week once insurance and FEMA did their walk around. I was told not to repair anything until they showed up. Definitely still a mess but we are getting there.
さんによる
コメントを追加
where is the solution @oldturkey03
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
@shails same model TV? Same issue? did you check your main board? Connections etc?
さんによる
Having the same problem as most when watching Netflix or Amazon, the bottom third of screen would have a horizontal bar that flickered constantly making it hard to watch a program. My son came in and grabbed the TV remote, went to settings, picture, and selected back light function and changed setting from 19 to 17 and the bar and flickering went away. Hope this works for some that are having the same problem.
さんによる
コメントを追加
回答を追加する
Ray さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 35
今までの合計 41,546
