My audio output doesn't work.
listening music from the speaker works. when i use earpods (wired) it doesn't work. i cleaned it like 5 times. it still does't work. help me please
@abdulsethi01 I am sure you have checked to make sure that your earpods are working. If so then it is possible that your headphone jack is not working properly. When you insert your earpods it activates a switch inside the jack and should "reroute" your audio. Since the jack is modular you do want to check the ribbon cable and connector on the board. If that looks ok, replacing the jack may just fix that. The Samsung part number for that is GH59-13416A so doing a search on that part comes up with plenty of suppliers.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 18
今までの合計 196
