I cant remember my pin number to get into my phone
What do u do when u cant remember your pin number to get into your phone
この質問は役に立ちましたか?
If you have forgotten your password turn off your phone after it turned off hold Volume Up +Home Button+Power button together , free them after seeing a New page , In that page With volume up and down go Up and Down and With Power button Confirm it.
Come down to Factory data reset And press power button for confirmation and then come down on yes answer and Press Power button.
Without the passcode, You will need to reset the device to factory settings unfortunately.. Keep in mind you will lose all data that is stored on the phone, so hopefully you have a backup! There is no way around this.
To reset this model you need to first power it off completely. Then hold the power button, home button, and volume up button simultaneously . Once you see the boot logo, you can let go of the power button. This will take you to the recovery screen. (may take a couple tries).
Then you'll want to use the volume buttons to select "factory data reset". It will erase the info, then reboot. Should be good to go from there.
コメント:
This is correct, the big thing people need to remember is if you inputted a Google Account (GMAIL) you will also be required to sign into your account otherwise you're going to prolong obtaining access by doing a Password Reset.
Juax さんによる
I have tried this method and it don't work. What can I do next?
Lucia Perez さんによる
Hey Lucia! What did not work exactly? Were you not able to get into recovery mode? And what was the issue with the device?
Andre W. さんによる
過去 24時間: 0
過去 7 日: 4
過去 30 日: 24
今までの合計 506
I did that but when i turns back on it still wonts my pin code,& i cant remember it
Lorraine さんによる
Hmm if done correctly the phone will be completely wiped, and the passcode removed. Are we talking about the gmail account maybe?
If the lock screen is still coming up, try following the steps again, as it likely did not reset.
Andre W. さんによる
I have followed these step and rest my phone but it still says "Unauthorized attempt to factory reset.
Lucia Perez さんによる
