How do I take off bottom cover of washing machine
water is leaking out of bottom of washing machine. i have it on blocks off the floor to see where it is leaking. dont know how cover comes off.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
ray, to remove the bottom front access panel just remove the 3 Torx screws on front bottom of machine. Slighty lift the panel and pull the bottom towards you. and here is the online service manual :) http://adcxns1.whirlpool.com/Service/Srv... good luck to you.
このアンサーは役に立ちましたか?
+ congratulations on finding that manual
What kind of screwdriver? I am having the same issue
The 3 Torx screws would require a Torx driver
what size is the torx screw a whole set is 22.00 $
過去 24時間: 1
過去 7 日: 12
過去 30 日: 70
今までの合計 19,599
