How do I open it so I can dry it out
I dropped my phone in water and i need to open it in order to dry it out. How can I do this without potentially damaging it further
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Afternoon,
If you do not have the proper tools for it, I strongly encourage you take it to a repair service that can assist. There are potential hazards if mishandling, which could lead to the unit being obsolete.
Link below for Teardown so you can get to where you want to be.
For cleaning guides see IFixit's guide
このアンサーは役に立ちましたか?
Drying out your phone is the worst thing you can do to it. DO NOT put it in rice and DO NOT try to dry it out. The best think you can do is put it in 91% Isoproyl alcohol. It will destroy your screen but it will save your data. If you wait until the water drys you have waited too long as corrosion will probably have already taken place. If the water has dried the best thing you can do is find a repair shop that specializes in board repair as they can desolder the shields and run it through a good ultrasonic cleaner and replace components on the board as necessary.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 15
今までの合計 2,131
