RAM Upgrade to more than 16Gb?
My new top of the line (maximum options MBPro) struggles more to cope with large files and edits in Lightroom than my old one.
Can the RAM be further increased to more than 16Gig?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If you didn't buy the upgrade from Apple, no.
If Apple didn't make that option, no.
This machine has ZERO upgradeability. All upgrades must be purchased upfront and requires Apple providing the option in the first place.
このアンサーは役に立ちましたか?
There was no option of more RAM available
The only option was to get the larger SSD storage which would have helped a bit.
Apple, in its infinite wisdom, is telling you that you don't need more RAM.
There is nothing wrong with your Macintosh.
Do not attempt to adjust the picture.
We are contolling the transmission .
If we wish to make it louder we will bring up the volume.
Is we wish to make it softer, we will tune it to a whisper.
We will control the horizontal.
We will control the vertical.
We can roll the image. etc., etc
We will control all you see and hear
このアンサーは役に立ちましたか?
@mayer - I love it:-}
hello ! :D https://www.youtube.com/watch?v=e-acbB0d...
Well, I suppose if you were DosDude2 you could upgrade the memory, but for us mere mortals that don't do chip-level swaps and mods, we're out of luck. When I was getting a newer MBP for my daughter (she had a mid-2009) I researched which was that last fully-upgradable model, and got a mid-2012 for her on fleaBay (bought one w/o a disk and a minimal amount of memory, since I was upgrading those).
Now her machine is acting up, and I may have to get a newer one for her (would rather give her a ThinkPad with Linux, but she was using some Mac Apps)
@mayer is right. Apple products are products from the Outer Limits, certainly not from here on Earth.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 9
過去 30 日: 45
今までの合計 14,635
1件のコメント
Sadly, you're not the first to need more than 16 GB of RAM.
You might want to look at freeing up as much space on your internal SSD storage as you can as I'm sure you are running lean on free space. That way your system will be able to leverage it for virtual RAM. For storage of your work get a Thunderbolt external RAID drive (SSD if you can swing it).
DanJ さんによる
