メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
How difficult is it to replace wifi ic?
Picked up an iPhone 6 on the cheap ($60) with greyed out wifi. Because there's not a massive risk in the price, do you think it'd be possible to replace the Wifi IC successfully or is it a difficult task that I should let a specialist do?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
I guess if you have to ask the question, then yes, it is too difficult for you to do :>).
This is by no means an easy repair unless you have the proper tools and some experience working at this scale. It certainly shouldn't be the first thing you try. There are plenty of videos on youtube that make it look easy but these folks are generally using multi-thousand dollar micro-soldering workstations under stereoscopic magnification.
Do you have a hot air station (not a heat gun)? Are you experienced in removing micro-BGA IC's from densely packed iDevice logic boards?
If you don't feel comfortable doing this yourself, then look for a repair shop that does micro-soldering repairs. It shouldn't be a very expensive repair.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
@refectio thanks! I'm pretty new to repairs and completed nothing close to a wifi IC, I guess I'll stay away from it then haha
さんによる
コメントを追加
回答を追加する
Matt Howard さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 11
今までの合計 1,408
