メインコンテンツにスキップ
モデル番号A1312 / Mid 2010 / 3.2 GHz Core i3もしくは2.8 & 3.6 GHz Core i5もしくは2.93 GHz Core i7, ID iMac11,3
382回答 すべてを表示
Control high fan speeds on iMac 2010?
Hello,
I was able to save a mid 2010 iMac from being thrown out at the office today.
Turns out it works perfectly fine, except the fan is way noisier than it should be.
The hard drive has been changed to a Samsung SSD 850 EVO at some point and I'm guessing the high fan speeds has something to do with this.
Is there something I can do to control the fan without tearing the computer apart?
Including screenshots from iStat from when the computer has just been started:
...and when it's been running for 20 minutes:
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
6件の回答
ベストアンサー
There is absolutely ZERO risk of using a software program than sounding money for a dumb cable. The software work exactly the same. I've been running a 2010 with SSD in it for icer 4 years now with software controlling g the two fans and I do graphic design and they're whisper quiet until I out the machine to work and they slow down when they aren't under a load. Don't believe otherwise. Sure the cable works too but the software dies the sane %#*@ thing
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
You guessed correctly. apple used propriety hard drive with propriety heat sensors so you couldn't use an off the shelve drive to replace with. If you did, you got a run away fan..
Here's the solution:
https://eshop.macsales.com/item/OWC/DIDI...
このアンサーは役に立ちましたか?
スコア 3
6 件のコメント:
Thanks guys!
Will start with trying out some software solutions, otherwise I'll go with your recommendation.
さんによる
Don't use a fan control software program to solve this problem as it doesn't. All your doing is telling the fan to run at a certain speed regardless of the temperature.
さんによる
I've seen to many systems killed this way :-{ Penny wise - pound foolish
Get the OWC in-line sensor
さんによる
Hmm... that doesn't sound good...
But I just tried this: http://exirion.net/ssdfanctrl/
It worked instantly. And I run it on S.M.A.R.T, so it should retrieve the right temperature without the cable and adjust it accordingly as far as I understand it? This computer will be used sparingly, and if I can save 50 dollars and a afternoon of tearing it down, I'll go with this. Thanks for the warning though!
さんによる
You can lead 'um to water but you can't make them drink.
さんによる
1以上のコメントを表示
コメントを追加
Usually this is caused because the SSD was installed, and the thermal sensor cable was neglected. Unfortunately the Mac gets confused and runs the fans high to compensate. OWC has a kit for the SSD's Link to Part
Try this. There is apparently software alternatives, but I cannot recommend as these kits are all that I have used.
Hope it helps! Good catch on saving the Mac, and happy repairs.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Thanks Charles, I’ve been doing the exact same thing and so far it has worked without problem.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Klas, maybe you´re swedish but I´ll write this in english anyway. I have the same problem, I´m thinking I should try Mac fan control since it is free to download and since I guess I won´t be needing the fan anyway I´m thinking I should just ajust the CPU fan to zero. Or should I buy the OWC for 45$ and do it the proper way? Or do you recommend SSDfancntrl instead?
holger
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Hello Holger! I'm from Sweden, but let's stick to english so everyone else understands too :)
I only have experience with SSDfanctrl, but I'm sure there are other softwares that does the same thing. I'm certainly no expert, but putting the fan to 0 sounds risky to me. My software runs on 1000 rpm as standard, which is maybe more than necessary, but it works perfectly fine like this so I've just kept it that way.
さんによる
Great thanks, I Will try Mac fan control and jeep at 1000rpm
さんによる
コメントを追加
I use an earlier iMac temp sensor that mounts externally on the hard drive. They have to be rewired to the logic board connector and then they work perfectly fine without a fan control app. It is Apple part no. 922-8165, the clip that holds it is part no. 922-8183. Should be able to get them for well under $10.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Klas Hjelm さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 46
今までの合計 10,287
