Rear wheel brakes have greses on them
a leake from the axel on brakes
If you sniff it n almost barf, its an axle seal (gear oil smells nasty). If its kind of slick, but not as viscous as motor oil, its brake fluid, and therefore wheel cylinder in the rear brake.
このアンサーは役に立ちましたか?
I think he knew what it was. The question is how to fix both the leak and clean the grease off.
@mayer figured I'd diagnose then display procedures
@theimedic good idea. I'll go take a nap while you display them ;-)
@mayer I took the nap...
Wow, a twenty hour nap. Hope you're feeling much better ;-) Sorry, @theelitepro_gd Vinicuis has been putting me in a very bad mood.
Axle bearing has failed,
This is always first case of any axle gear oil to escape.
And Yes, it is nasty rank smell,
Now get it hot enough to smoke from using brakes,,
as a default,,, gear oil soaked brake shoes will tend to lock
up the rear wheel even light pressure of brakes.
The brake shoes can be salvaged,,, but they will need
To soak in high grade solvent,, typically Naptha in first
phase,, then brake cleaner for final phase.
But if local source has them cheap, simply replace,,
As Farmers,, we tend to give stuff a second chance regardless.
Best of Luck
Quick note,
typical throw away axles need to have bearings
Pressed On.
But not impossible with clever tooling.
Quick note 2:
If axle is too damaged at seal area,
There is option for offset bearing
To allow seal to get new surface,
Also speedy sleeve is 3rd option to salvage seal zone.
Quick note 3
This would be great time to flush out rear end
and upgrade the oil.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 85
