メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2016年モデルのSamsung Galaxy J5(型番:SM-J510FN)の修理および分解のガイドです。
back button & apps button KEYS not working
Apps button & Back Button not working, tried that Firmware version (*#2663#) thing also, TSP FW update and Touch key FW update both, still not working. Please help its == Samsung J5 ==
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 10
3 件のコメント
Just replaced lcd on a friend's note 5 and back/recent keys will light up but no action.. have tried (*#2663#) ,hard/soft reset with recovery reboot and deletion of partition cashe', With no avail. Is it possible the ribbon cable connection for the lcd isn't a complete one? Allowing the picture but not the soft key functionality?
さんによる
It should be noted that the light for the back button and recent apps button might also be turned off if your samsung is in Power Saving mode. Go to Settings>Power Saving>Restrict Performance and uncheck the box that turns these lights off. Once the box is unchecked, your phone will use a little more battery power in the Power Saving mode, but your Back button light and your Recent apps light will both illuminate.
さんによる
If you want a permanent fix order the touch capacitive buttons + home button + headphone jack online and install it
さんによる
コメントを追加
4件の回答
ベストアンサー
Hi!
This is what I've got for you.
Go to Settings > Accessibility > Dexterity and interaction > Assistant menu
From here, toggle the switch to "ON". This will create a hovering circle with a window with four panes inside it. If you interact with the hovering circle it will open a new window in which you have access to the back and recent apps buttons via an onscreen button.
Not sure what has disabled the hardware buttons, but this should give you access via onscreen software.
I know it's not a true fix, but a work around.
このアンサーは役に立ちましたか?
スコア 21
16 件のコメント:
Omg it works!!! Thanks you so much
さんによる
It Worked. You Made My Day. Thanks.
さんによる
What do I do with the last windows
さんによる
Great ... good solution
さんによる
Thank you Alex!!! God bless you!I have trouble this for 4days
さんによる
11件以上のコメントを表示
コメントを追加
If it is similar to the j3, the screen is above two sensors that look like small circuit boards. I replaced a screen a while back, and ran into the same issue. I took the screen back off and re installed it. I made sure to line the groves on the bottom of the screen with the small touch sensors. It fixed the problem for me. When installing a screen you should always test it first. You can plug the screen in, turn the phone on, and dial *#0*# this will bring up several test options. The touch test will allow you to test the digitiser, and the subject test will let you test all the buttons including the back and apps button
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Sub key test* not subject. Sorry for the typo
さんによる
Back button app. is the last solution, but is working.
さんによる
コメントを追加
I have a j5 prime with the exact same issue, I found app in app store called easy home for samsung. It works perfectly, hope this helps
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Turning off "Power Saving" fixes the issue of backbutton not working. This is an annoying bug.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Lionel Myers さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 31
今までの合計 106,361
