iPhone 6s Battery compatibility (APN)
Can i use a battery with APN 616-00036 instead of 616-00033 that is the one allready installed in the phone??? Are they compatible?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Battery compatibility issues are no longer an issue with recent iPhones. You can check out this previous Answer (Battery APNs, how much is important?).
Order your batteries from a trusted source, like iFixit and you wont have problems.
このアンサーは役に立ちましたか?
Thank you, Minho!
Yes,
Compatible with Part APN#: 616-00033, 616-00036 / Voltage (V): 3.82 / Watt Hours (Wh): 6.55 / Capacity (mAh): 1715mA
このアンサーは役に立ちましたか?
Thank you, Michael!
YES SIR . You Can Use Battery With Your iPhone 6S APN 616-00036 - 616-00033...... this to same iphone 6s Battery ..... APN NUMBER
このアンサーは役に立ちましたか?
Please remember. The older 6s MUST HAVE 00033.
The 616-00036 does not fit, even after "moving around".
このアンサーは役に立ちましたか?
My original battery model is 616-00036 (Maker: Huapu Technology) after it reached a battery capacity of 84%, 1 removed it and replaced with 616-00033(Maker: Desay).
I had trouble installing the 36 where a 33 came out. It behaved as though it was the wrong battery
Angling and tipping the connector, rolling onto the logic board (instead of installing parallel to the logic board surface) helped and it went right on. :)
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 2
過去 30 日: 8
今までの合計 7,201
1件のコメント
I don't get it. My phone thinks that's a phone number
iMedic さんによる
