Possible causes in vertical lines of LCD
A few days ago I tried to increase the memory of two iMac's, from 8GB to 16GB, using memory with factory specifications.
In the first everything turned out as expected, however, in the second, after making the change, the LCD screen showed two vertical lines since the system started. I replaced the original memories and the problem persists, have I damaged any components?
Which component could have been damaged? Thank you very much for your comments and suggestions.
Actualización (24/08/17)
This is how look
この質問は役に立ちましたか?
1件のコメント
@joepep post some pictures of what your display shows with your question. That way we can see what you see. iFixitでの質問に画像を追加する方法
oldturkey03 さんによる
