メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Unable to activate Touch ID after housing replacement
Hi,
one day ago I replaced my used and damaged IPhone 6 Housing with a new one (not a used one; Bought a new one from ebay in matte Black and Gold). So far so good, but after i reassembled everything, my Touch ID wasn´t working correctly, so did a reboot and i did a soft reset with the hardware keys. After this I got the Message, that it`s "Unable to activate Touch ID".
I also changed the ribbon cable on the back of the metal plate on the Display and tested the old one with another IPhone (it worked)...
I am really confused now, since i didn`t touched the Home Button at all (no need when you don`t change the Display...)
Any recommendations?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Did you simply change the metal housing, or did you change any of the internal parts (like the logicboard)? Since each home button is paired to the logicboard, replacing either the home button or logicboard will disable Touch ID. If you are still using the original logicboard and home button that are correctly paired, it is possible that you damaged the home button cable.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yes you have to remember that the home button with same phone only works not other.Maxium chances is that the home buttom flex is damage or on home buttom clearly check out there is on crystal ic try to clean with.
さんによる
コメントを追加
Try resetting all settings.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Daniel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 608
