メインコンテンツにスキップ
The Samsung Galaxy Tab 8.9 was released on October 2nd, 2011. Model number: GT-P7310
Why is my Tab not coming ON?
hello, I have a tab 8.9 4G p7320T which does not power ON.
I was trying to enable gsm voice call on it. So I first of all flash CWM recovery so that I could install the necessary zips to enable the call system. After flashing CWM, I now copy the zip files to a folder I created in the internal memory since the tablet doesn't take sd card. I successfully install the zip files but forgot to wipe cache and dalvik cache and went straight to restart. Since then till now it's not powering on, not entering into recovery mode, not entering into the downloading mode or showing sign of charging when the charger is plugged.
Also, when I plug the usb cable to my computer, it say format disk,
Pls what can I do to restore my TAB
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
try disconnecting the battery and leave it unplugged for five minutes or so . this will wipe the cache and give you a fresh boot
Samsung Galaxy Tab 8.9 Battery Replacement
This guide will show how to open and locate the battery connectors . You don't need to remove the battery just disconnect it . that said you also do not need to remove the video cables in steps 5 6 and 7 so skip straight to step 8 once you have your tablet open . Hope this helps
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Its not still coming on
さんによる
コメントを追加
回答を追加する
Nyimeh Gweh Gerald さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 283
