メインコンテンツにスキップ
2014年10月16日に発売された iPad Air 2は初代 iPad Airの継続版でより薄くなったスタイルです。
450回答 すべてを表示
Screen appears to have soft wrinkles after replacing camera
I bought an iPad that needed a new rear facing camera.
I CAREFULLY opened the iPad, disconnected the battery, found the defective camera, replaced it, reconnected the power supply, and now the screen appears to have soft, undulating wrinkles on the upper half.
Looking for any answers!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
Hi and thanks so much for your response.
The initial problem with the iPad was a bad rear camera, which is why I opened it. I used playing cards to pry the digitizer off and might've accidentally dug a little too deep between the digitizer and LCD. Pulled out two small pieces of 'wire fabric' looking stuff from one edge of the joint between the digitizer and LCD. I never even detached the connector or took off the cover plate.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
What did you use to apply heat to get the adhesive loosened? Sounds like you used a hot air gun and it overheats the diffusion on the LCD panel causing it to wrinkle when it cools.
さんによる
コメントを追加
That sounds like it might be a loose connection or damage on the display cable. I would attempt to reseat the display cable and try again. When you reseat the display cable, don't put the iPad all the way back together before testing to avoid needlessly replacing the adhesive multiple times.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Try not to tighten the four lcd screws to much, if the problem still remains try applying a little heat from a save distance. This could help retract the wrinkles.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Craig Sweeny さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 18
今までの合計 999
