メインコンテンツにスキップ
MacBook Proの13インチディスプレイ搭載モデルの修理情報・ガイドです。
9745回答 すべてを表示
Browser Virus problem showen
HI
How I solve this problem please check the attachment every browser I use this massage shown to me plus a sound beep coming out
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
If your browser won't get off this screen. start up in Safe Mode by holding the Shift key down. Now you should be able to open the boozer and get it off that screen. Then reboot. Your machine is not infected by getting this but having a paid for anti-virus prevents this from happening as it will give you a noticed before one of the pages loads most of the time. I use Symantec Endpoint Protection.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Hi - this is a fake website, not Apple. You need to run an anti-virus scan to stop it from popping up every time you use your web browser.
I recommend using 360 Total Security, since it does a full scan of your Mac. Don't pay for the premium plan though, the free version works perfectly. https://www.360totalsecurity.com/en/feat...
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
This is a kind of ransomware! Forcing you to use their product which just infests you more!
If you clicked you are likely infected! Don't open unknown messages! Make sure you don't view your messages in the main menu (close it) and instead move them un-viewed into your Junk folder on only there check the sender field.
さんによる
コメントを追加
回答を追加する
ghmax2010 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 64
