Are iPhone 7 plus screen and 6s plus screen interchangeable
I have an iPhone 7 plus I cracked the screen it's still very new was wondering if I could repair the screen with that of my 6s plus
この質問は役に立ちましたか?
この質問は役に立ちましたか?
No. Every single connector on the display is different and will not fit nor work.
このアンサーは役に立ちましたか?
Agree with Ben. It won't. The only ones that are interchangeable are the 5s/SE.
このアンサーは役に立ちましたか?
The front glass only will fit the iphone 6 plus and Iphone 7plus. The other connecting components connections will NOT match up. However you can order just the front glass replacement which is much cheaper than the full assembly if your other components are still operable.
このアンサーは役に立ちましたか?
So you can't put a 7 plus screen on a 6?
このアンサーは役に立ちましたか?
No way, besides size they have nothing in common.
過去 24時間: 3
過去 7 日: 12
過去 30 日: 39
今までの合計 22,678
