メインコンテンツにスキップ
Samsung smartphone released in January 2016. Model SM-J320
48回答 すべてを表示
How do I fix a black screen?
I had recently gotten a samsung galaxy j3. I accidentally dropped it into a pool, and dried it, I waited a few days and after a while, it turned on. the screen is illuminated, but stays black. Ive tried everything, even a reset but the screen stays black, The phone vibrates and the flash stays on when charging, but nothing happens screen wise, Do I need to get it replaced?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
I recently got a samsung galaxy j3, incidentally dropped into water, i dried it up to a week to ensure its totally dried. I put the battery and power it ON, it turns ON. Every thing functions perfect, but there is no light on the screen (dark), Its charging well. Please what do I do? can someone help..
さんによる
コメントを追加
2件の回答
ベストアンサー
There is a tricky part here. You dropped it in water, therefore it needs to get cleaned out immediate to prevent corrosion. This can be done with 90% isopropyl alcohol
There is still a chance the phone may work after cleaning, so don't give up!
If you cleaned the phone and issue still appears to be the same, then you will most likely need to replace the screen. Not sure if you have the exact model you posted but here is a breakdown for the a J3
If you're not comfortable in this realm, just take it to a shop and inform them it was dropped in a pool.
Hope this helps
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
my phone is brokekin
Update (09/02/2018)
its my screen my phone is broke
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mikey さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 14
過去 30 日: 16
今までの合計 3,035
