メインコンテンツにスキップ
モデル番号A1708/EMC2978ー2016年10月発売。このエントリーレベルのMacBook Pro にはこれまでと同じファンクションキー(OLEDTouch Barとは反対)が搭載されています。ファンクションキーモデルにはIntl Core i5と2つのThunderbolt 3ポートが付いています。
216回答 すべてを表示
Jump Pad location on this model
I got one of these in last week with a keyboard liquid spill. It will not power up. Due to the cost of the upper case and inability to change out just the keyboard, my customer decided not to attempt repair and traded in in to me for a working machine. Now I have a possible source for some very high dollar parts and replacements keys (which I have been unable to find). I need to jump the logic board to boot it up to test out the other parts and possibly recover the data off the SSD. I'm hoping either @danj, @reecee or @oldturkey03 might know where I can find this info. Bleach under display. this photo is with the display on.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
Sorry @mayer - Your ahead of me on this series ;-{
さんによる
コメントを追加
1 件の回答
ベストアンサー
No idea, haven't had many in myself. Should prompt boot when the charger is connected though, after reconnecting the battery; just disconnect the keyboard to ensure this isn't preventing boot too
このアンサーは役に立ちましたか?
スコア 3
6 件のコメント:
reece thanks, I switched this from a comment to an answer as this had slipped my mind and will resolve the issue. And it worked. Will have some high dollar scarce parts and a whole board of replacement keys now ;-)
さんによる
Good to hear. Not going to lie, I'm slightly jealous :)
さんによる
@reecee don't be. The customer had wiped it down with bleach, it infiltrated the display, fan is not working, found more corrosion on the logic board. I may come out with very little.
さんによる
@mayer ouch, they really did a number on it. Hopefully you can salvage some parts from it, and maybe even end up with test parts (in the case of the screen, if it has leaked in the backlight, it may still light up fine)
さんによる
@reecee Display works, see photo update. Machine boots & runs. Battery will not charge. We're going to pull the board again and clean some more.
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
mayer さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 6
今までの合計 743
