メインコンテンツにスキップ
1.8 GHz デュアルコア Intel Core i5(Turbo Boost使用時最大2.8 GHz)3MB L3キャッシュ
20回答 すべてを表示
Lid will not shut completely. Hinge too tight?
I have a 2012 MacBook Air, obviously out of warrantee, that suddenly will not close all the way. It was a problem on one side only at first, but it’s getting worse with a half inch between the lid and the body of the machine. I opened it up and removed the screen. I’ve found that one hinge is moveable with my fingers alone. The other is so tight it needs a wrench to move. I can’t tell which is “normal” or if either is the problem. I can say that when the machine is assembled the tighter hinge will not move past a certain point when closing and that may be the reason the screen bounces back open. My only idea is to wd40 it a bit to see if it loosens up, but I’m loathe to do such a thing without checking here first. I wouldn’t want a screen so loose it can’t stay open.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
2件の回答
ベストアンサー
I've never had to use anything like WD40 on hinges. Use this guide to reseat the hinges correctly. Something else may be going on here and posting a couple of pictures might help us figure out your exact issue. MacBook Air 13インチ Mid 2012のディスプレイアセンブリの交換
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
Added pictures to the initial post. Hope they help. The tighter hinge is the one with the iSight/airport cables. The looser one has the display cable. You can see how big the gap is when closed.
さんによる
Well I see a lot of crud in the hinge. I's use a q-tip dripped in alcohol to try to clean the hinges out.
さんによる
Ok, I dripped some alcohol into the hinge and moved it while picking grime out with a toothpick. That loosened it to moving again without needing a wrench. The lid is closing, though I don’t know how thorough a job of cleaning I managed. At least I know the problem now and in the future! Thanks!
さんによる
Taking the whole display apart is going pretty far. I would try cleaning the hinges with isopropyl first. It did the trick for me. If cleaning doesn't do it, then it may be time to escalate. :)
さんによる
I have the same problem with Macbook pro retina 2013. are steps the same?
Thanks,
Marina
さんによる
1以上のコメントを表示
コメントを追加
Hi All
Many thanks for sharing your experiences and help here.
Long story short, I had lid closure issues and diagnosed a bulging battery. I replaced the battery, which was only mildly bulging, and the lid still refused to stay shut.
Having read experiences here, I used the below link to learn how to remove the screen, and then clean and lubricate the hinges (which were very stiff) with silicon lubricant.
It worked, and the lid now closes perfectly again.
https://www.google.com/search?q=adjust+t...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mark2000 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 42
今までの合計 8,226
