メインコンテンツにスキップ
2012年半ばモデル、A1278/2.5 GHz i5または2.9 GHz i7プロセッサー。
1624回答 すべてを表示
Ocaasionally freezes and opening apps in launch pad is too slow
System: Macbook pro 13" Mid 2012 2.9GHz i7.
Graphics: Intel HD graphics 4000
opening Launchpad is too slow but over all machine runs fine when I use lightroom/photoshop.
Booting time also increased - O/S is on SSD and all apps are installed on SSD.
Occasionally system freezes. Need to hard boot.
Took it to genius bar and they suggested that most probably motherboard is gone and they said it costs around $450
Is there any way it can be quick fixed without changing mother board and if need, is this something doable.
Also, is it really worth it? Genius bar guy is telling to live with it and instead spend money on new laptop...
System is modified almost 3yrs back to SSD and HDD (removed optical drive)
Last year upgraded SSD to 1TB.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Did the Genius Bar tell you about the Hard drive/IR cable program. They were replacing all the cables on the 2012 13" for free.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
He did not mention about changing the cables. Not sure, if this is because I modified the machine from original configuration.
Will changing those cables makes a change to slowness/freeze?
さんによる
Search this site on this machine and see how many of this same problem there are. My bet would be about 20 to 1 it's the cable. I even keep three in stock at all times.
Here's a list of the repair questions on this model:
https://www.ifixit.com/Answers/Device/Ma...
さんによる
I have to agree with @mayer here. These cables tend to breakdown overtime, where they are routed (bent) as well as were it rubs along the upper case. The newer version of the cable is better made..
さんによる
コメントを追加
回答を追加する
sainadhb さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 101
