Anybody have a way to replace the wristband?
This is the second band where the rubber wristband got a tear in it. Has anyone found a way to replace the rubber part with something else?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Someone on the Windows Central forums replaced their Band's band with leather, and it looks pretty neat: https://forums.windowscentral.com/micros...
You can also check out a more detailed guide to replacing the band here: https://band2repair.wordpress.com/
Also, if you're just repairing cracks, you can use Sugru.
このアンサーは役に立ちましたか?
This guide should help you, but in looking through all the guides this band contains components and you may need to go through all the guides to get it figured out:
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 1,666
