メインコンテンツにスキップ
Repair information for the Samsung Galaxy Tab 12.2, released in 2014. Model numbers: SM-T900, SM-T905.
Samsung Galaxy Tab Pro SM-T900 Overheating
What could be possibly causing my tablet to overheat, usually while playing games?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
1件のコメント
My tablet gets overheated whilw charging. It stops charging.
If charged, battery drains much faster.
さんによる
コメントを追加
2件の回答
最も参考になった回答
Currently staying in 40c ambient environment and this is my second TABPRO S, previous never had heating issues then I realised what I read about chrome... I use edge mainly but chrome for some things. On the new install I noticed very hot top right corner (I assume processor is there)... and then I remembered reading about chrome mullering battery’s and CPU useage...
I turned off the background activity for chrome and reduced sync to use two options that I actually benefit from...
In ''settings “Continue running background apps when Google Chrome is closed” and deactivate it... I sync bookmarks and browsing history only.
It worked immediately for me... TABPRO S no longer heating beyond expected.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
The internals of a device goes a lot of programs to work so most of the time when the device has multiple tabs or apps open at once the device can heat up. Also if the storage is low then the device can slow down and that could make the device warm up faster. And lastly when the device is in use for a long time the Comonents in the device can also heat up. This can also happen when charging and playing or using the device. ( sorry for my bad English )
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
How to get over it. I am told that battery need replacement. Will that be. If so, where do I get the battery in India.
さんによる
where do I find repair shop in Delhi India.
さんによる
Um you can try to oppen another device for the same type and take the battery
さんによる
I am also hues a kid so I really don't know that much but try not to use the device for few days and see what happens
さんによる
コメントを追加
回答を追加する
Marilyn Haynes さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 4,867
