Samsung Galaxy Tab Pro SM-T900 Overheating
What could be possibly causing my tablet to overheat, usually while playing games?
Currently staying in 40c ambient environment and this is my second TABPRO S, previous never had heating issues then I realised what I read about chrome... I use edge mainly but chrome for some things. On the new install I noticed very hot top right corner (I assume processor is there)... and then I remembered reading about chrome mullering battery’s and CPU useage...
I turned off the background activity for chrome and reduced sync to use two options that I actually benefit from...
In ''settings “Continue running background apps when Google Chrome is closed” and deactivate it... I sync bookmarks and browsing history only.
It worked immediately for me... TABPRO S no longer heating beyond expected.
このアンサーは役に立ちましたか?
The internals of a device goes a lot of programs to work so most of the time when the device has multiple tabs or apps open at once the device can heat up. Also if the storage is low then the device can slow down and that could make the device warm up faster. And lastly when the device is in use for a long time the Comonents in the device can also heat up. This can also happen when charging and playing or using the device. ( sorry for my bad English )
このアンサーは役に立ちましたか?
How to get over it. I am told that battery need replacement. Will that be. If so, where do I get the battery in India.
where do I find repair shop in Delhi India.
Um you can try to oppen another device for the same type and take the battery
I am also hues a kid so I really don't know that much but try not to use the device for few days and see what happens
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 4,866
1件のコメント
My tablet gets overheated whilw charging. It stops charging.
If charged, battery drains much faster.
nmgupta1 さんによる
