Upgrade CPU to i7
Hello folks, i wondered if its possible upgrading the dualcore cpu to the new i7 one? thanks
この質問は役に立ちましたか?
この質問は役に立ちましたか?
No, the CPU is attatched to the motherboard, and cannot be removed. In order to replace the CPU, you would have to buy a new motherboard.
このアンサーは役に立ちましたか?
is it possible to upgrade motherboard compatible with i7? so that i could upgrade CPU and to higher graphic chipset even if it is built-in to motherboard? thank you so much =)
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,760
