メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Screen Brightness on Replaced Screen From iFixit
I've replaced a few iPhone screens here at my company. One of the first users I assisted has noticed that the iFixit screen is slightly dimmer than his original screen. I used my iPhone with an OEM screen and it is noticeably dimmer not a huge difference but it is noticeable. Is that just the nature of replacement screens or should I try another replacement screen? Just curious if others have noticed the same issues.
Thank you.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
That's absolutely, yet unfortunately, normal.
There are varying quality levels in replacement screens and when you have aftermarket LCD's, they will typically be a bit dimmer and have shallower viewing angles. Lower cost screens will also have lower quality glass which can affect the touch sensitivity and make them easier to crack again. The biggest problem with low cost screens is cheap flexes, cheap frames and poor quality adhesive to hold it all together. They actually use hot melt glue some times or even worse, just double-sided adhesive.
iFixit tends to sell good quality screens and they even have a "Choice" line on some models that feature cold-pressed frames and original-quality LCD's among other things. The problem in the industry right now is that customers believe they are getting Original Apple screens when they pay someone 60$ to replace a screen. They don't understand that there are quality levels so everyone pretty much has to sell the cheap stuff to stay competitive.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Try toggling your phone's light settings
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I've done that ;-) I'm talking about I've upped the intensity on both screens and there's a noticeable difference.
さんによる
Screen must have, a slight tint on it, try another screen, if you still see this issue may be the phone itself.
さんによる
コメントを追加
回答を追加する
Jeff Poulin さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 1,158
