メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
Why is my iPhone not rotating?
My iPhone's compass and level doesn't work not only that but the auto-rotate function doesn't work and on top of all of that my phone doesn't ring despite the phone isn't on mute, it can only vibrate to notify me that I am receiving a call. What can I do to fix this?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
If you have already tried a restore then it's a hardware issue.
It's most likely damaged compass IC which only someone that does microsoldering will be able to fix as it would need to be replaced.
Usually these go bad from phone being dropped, physically damaged when doing a screen replacement or liquid damage.
Also the top right screw for the metal plate that goes over the screen connectors is demagnetizied as that is near the compass IC area to avoid interference.
If another screw was out there instead it may interfere with the compass IC.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
johndiaz693 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 244
