How do I install a printer driver for an HP laserjet 1012
How do I install a printer driver for an HP laserjet 1012 in Windows 10?
Download it manually using google and install, don't connect printer unless it says to do so.
このアンサーは役に立ちましたか?
I have an HP 1012 laser printer, it showed up on my computer as a storage device. Opening the storage on the HP1012 started an installation process that loaded the drivers enough to get it to work. The drivers are old and you should be able to click on the printer properties and find the driver properties and update the drivers through Windows 10 update.
このアンサーは役に立ちましたか?
Things to remember driver installation
Below are some important guidelines you have to bear in mind when installing the printer drivers
⦁ You should connect your HP Printer Drivers to a network by a wired or wireless option
⦁ For a wired connection use USB cable and use Routers in wireless connection
⦁ In the first place, know the model of your printer and its serial number.
⦁ Have your Network Name and password ready, during the driver installation process you have to key in the network credentials
⦁ Ensure that the network connectivity is up.
Till the above steps, it is same for Mac and Windows. Check below, to know the unique driver installation steps for Mac and Windows
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 4
今までの合計 1,023
