メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
No power after replacing rear case.
I completed a rear case replacement,, seemingly without a hitch. But now the phone won't power up. Either that or the display isn't working now. I checked the battery cable and display cable and they're plugged into their sockets correctly. Curious what else I should check.
I did accidentally re-connect the battery to the logic board at one point before completing the assembly. I quickly disconnected it after realizing I had a few more steps before I was supposed to plug it in, but I wonder if I could have fried the logic board by jumping the gun.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
Is it completely no apple logo?
Try plugging it into a computer. A couple things to try unplugging are the home button extension cable, power button cable and volume button cable.
さんによる
My guess is the battery went dead or you shorted the logic board by mistake. Try getting a new battery and connect it to iTunes. If it doesnt show up i think its board level issue, and be careful to know where every screw goes. Common way to short the board is when you are connecting antenna cables.
さんによる
コメントを追加
1 件の回答
Hi
As a repair guy (for over 8 years) I can set your mind at ease. I have done countless iPhone 6 repairs and simple connecting the battery to the motherboard can not damage anything. Doesn’t matter what’s connected or not.
The only way you could short something is when you connect the battery, turn it on by pressing the power button or connecting it to a charger cable, and then, when it’s power on, connecting the camera or the screen when the device is ‘hot’. The iPhone 6 motherboard is strong enough that connecting the screen, even when the device is on, wouldn’t cause damage if the screen isn’t lit. Iff it is, the backlight coils probably would burn, but as I said, never happend to me. And for all your DIY’s, DONT TRY THIS AT HOME, turn of the device and disconnect the battery before making repairs !! Just to make sure, as the 6S for example will surely burn out the backlight if you forget this
So, as mentioned in the comments, connect it to iTunes, to make sure it’s not the screen that’s stays blank (wait 30 minutes to make sure the battery wasn’t depleted).
Iff iTunes does notice the iphone check the backlight. hard reset and use a bright light reflecting in the screen, the apple logo is visible (but only barely). Iff so check the backlight soldering on the back of the LCD screen and its flex cable. If it looks fine you probably damaged the motherboard backlight coils.
Test with a new battery, with enough juice in it (all new ones have at least 40% charge). If you have a volt meter, test the current battery. It should score about 3,85 V or more, otherwise the iPhone hasn’t enough to power up.
Iff you used a housing with a new dock connector flex cable as well, maybe this is faulty, not powering the motherboard and the battery, so connect your old one and see what happens.
Iff you did all this and it still not working, than it’s time to buy a new phone.
Good luck
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ryan Palmer さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 51
