メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
replaced battery will not charge
Hi, got a new battery and replaced it per instructions, ran the battery down below 10% as instructed, tried charging it, nothing happened, used 3 different cord on wall charger, also tried my car charger and nothing, connected to laptop to see if the computer saw the device, still nothing, any ideas? removed battery a few times to make sure the plug was right. any other way to charge the battery besides using the 30 pin connector?
Thanks Greg
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
This can be three different things. Two easy, one bad news.
First this is faulty charging port. If the device is on but no charging connection, this charging port component will need to be replaced.
iPhone 4 Dock Connector Replacement
There is a difference in charging port between CDMA and GSM models. Make sure you get the right one.
Second thing could be a faulty battery. Although this is more unlikely aince the battery does seems to operate.
Third, if all else fails is motherboards issue, which you will need to contact a professional for advise on how to repair the device.
Happy repairing!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Greg Wischmeyer さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 49
