メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年9月25日に発売。モデルA1687/A1634。このデバイスの修理は前モデルと似ています。スクリュードライバーとこじ開けるツールが必要です。GSM もしくは CDMA。容量は16、64か128 GB。カラーはシルバー、ゴールド、スペースグレイ、ローズゴールド。
Front facing camera replacement
Hi there
I need to replace the front mic of an iphone 6s plus. I suppose that I need to replace the camera and everything at the same time. Would the camera form iPhone 6s work?
This one here: iPhone 6s Front Camera and Sensor Cable
regards
Frímann
Replace a front camera and sensor cable assembly compatible with the iPhone 6s. Includes the front camera, secondary microphone, ambient light and proximity sensors. Part #821-00123-01.の画像
製品
$22.99
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
laukur, Directly from your link in your question. Compatibility of iPhone 6s Front Camera and Sensor Cable, Item code: IF314-015-3 for All iPhone 6s , ((Not iPhone 6, 6 Plus, or 6s Plus)).
As far as having to replace the camera because you need to replace a bad mic. which is part of the lightning assy., camera should not have to be replaced unless defective.
Lightning Connector Part Assembly includes:
Lightning connector
Dual microphones
Headphone jack
Links below are for replacement part and guide for installation of the Lightning Connector Assy..
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
iPhone 6s Plus Lightning Connector and Headphone Jack
iPhone 6s Plus のLightningコネクタとヘッドフォンジャックの交換
Replace a battery compatible with iPhone 6s Plus Models A1634, A1687, A1690, and A1699 smartphones. Part #821-00126-A.の画像
製品
$24.99
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
TL:DR You need to use the 6s plus front replacement camera.
The normal 6S front cam will not work.
さんによる
コメントを追加
Hi and thanks for your reply! However I think there is some misunderstanding. It's the front mic by the earpiece and close to the front facing camera (facetime camera often called) that is broken. I believe your directions were for the mics at the bottom of the phone (by the headphone jack)
Regards
Frimann
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
laukur さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 157
