メインコンテンツにスキップ
A portable wireless bluetooth speaker introduced in 2013 by Beats by Dr. Dre.
27回答 すべてを表示
Flashed Beats Pill Plus
My company was recently throwing away a Beats Pill+ that has been "flashed". They told me I could have the speaker if I wanted because it was going in the trash anyway. The flashed Pill has been reprogrammed to only work with an aux cable and when it is plugged in. The Bluetooth and charging capabilities have been disabled. This was done in case someone stole it during our expo they wouldn't be able to sell it. Is there anyway for this "flashed" Pill+ to be reverted back to factory settings? Thanks.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
Nah the factory reset didn't work. I think is was programmed either from Apple or Beats to not be that easy to revert back to the factory settings.
さんによる
Same problem did anyone else get any suggestions please update
さんによる
コメントを追加
1 件の回答
ベストアンサー
So there is, however I'm wondering if the settings it was originally on was a display mode, which will likely be unuseable to anyone besides the retailer. Here, try this first, then come back to us
Use the Lightning to USB cable to plug your Beats Pill+ into a power source.
Turn the speaker on.
Hold down both the "b" button and the power button for 6 seconds.
The Fuel Gauge flashes red 6 times.
Your Beats Pill+ is restored to the settings it had when it was purchased.
このアンサーは役に立ちましたか?
スコア 4
3 件のコメント:
さんによる
Correct my guess is that the factory settings are set up for display. So no one can steal it. It can be erased/reset but you'll likely need some code, from the supplier
さんによる
Does the answer to reprogramming it involve coding or wiring?
さんによる
コメントを追加
回答を追加する
Tee Dubs さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 9
過去 30 日: 34
今までの合計 4,029
