メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Are iFixit replacment logic brds for iPhone 6 at risk of touch disease
probably a question for the iFixit crew.
I'm about to buy a new logic board for iPhone 6 as mine is suffering badly from touch disease, although I have never had the grey bar.
Just want to know if I buy a replacement logic board for an iphone 6 from iFixit if the touch IC's have been checked/re-soldered and so on.
Or could the same thing happen again.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Ok, so the board itself isn't at risk of touch disease, apples crappy frames for 6 and 6 plus are the issue. With that being said, iFixit does offer plates, to help keep the chips in place, as well as new soft covers, if you can't get the old one off and on without hassle
That's weird...can't seem to find em...and I asked for those new soft covers specifically!
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
So, it the common currently accepted solution to resolving the touch issue to replace the logic board and then to place a plate on it? I know this is a year-old comment but I am having a hard time finding what the currently accepted solution is that doesn't involve rewetting the solder under the IC.
さんによる
@kupajava The current best practice is to remove the Meson IC, place a micro-jumper on the M1 pad and reball Meson. No need for a plate. This is about as permanent a solution as you can get.
さんによる
コメントを追加
Theoretically, it could. However, iFixit stuff is great quality. If your motherboard is affected by touch disease, it is backed by their awesome lifetime warranty. I don't know exactly where there sourced, but if I had to guess I'd say they came right from some new iPhones. Utmost quality.
Hope this helps!
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
pep073 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 107
