メインコンテンツにスキップ
2009年6月発売/ 2.53 GHz Core 2 デュオプロセッサ
170回答 すべてを表示
Keyboard stuck after spill
Hi,
I'm trying to recover my laptop after spilling coffee on it. I followed the guides here on ifixit to completely disassemble the machine and dry it out. I see no signs of corrosion on any of the components but:
-Keyboard does not work, as if a single key ("2") is permanently stuck, almost all other keys are non-responsive
-Does not work from battery
I'm getting a new machine in a few months but wanted to keep using this one in a limited capacity until then. I would be happy if I could disable the internal keyboard and just use keyboard viewer. Eventually I will pick up an external keyboard but wanted to make sure this would work first. Strangely, I get the same behavior using keyboard viewer to enter text as I do using the physical keyboard. I even tried physically disconnecting the keyboard from the logic board, but the system won't boot if I do that. Any suggestions on a work around?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
I spill will usually short out a keyboard. I have had great success replacing theses boards. It's a lot of work doing all the screws and takes about 2.5 hours, but sure beats buying a new machine or an upper case.
Here's a guide that shows how to do ti: MacBook Pro 13" Unibody Mid 2010 キーボードの交換
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Aaron A さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 13
今までの合計 111
