メインコンテンツにスキップ
The Nissan Xterra is an SUV that was manufactured and marketed by Nissan Motors across two generations, utilizing its Nissan F-Alpha platform shared with the Nissan Frontier pickup.
34回答 すべてを表示
The clutch wont engage on compressor unless I squeeze the relay magnet
2002 nissan xterra, new compressor, new thermal control amplifier. The compressor works but the clutch wont engage unless hard wired to battery or i squeeze the magnet in the relay. I tryed switching the horn relay to see if it was out and it didnt work. Any help please i have a 10 month old baby to drive around in this texas heat!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
選択されたソリューション
@texasheat as @jimfixer already suggested, one of the main causes for that can be a low level refrigerant. there are also a few more things that you could check. Problems like these are hard to troubleshoot. You can test the AC relay properly by following the procedures outlined in the manual. After the relay you only have some thermal protection before the compressor. Start off with the "Nissan trouble Diagnoses" and see where it takes you:
For more of the way your AC works and complete wiring diagram and diagnostics etc. use this part of the manual XTerra Heater Air Conditioner
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
最も参考になった回答
Odds are the compressor is not engaging without being hot wired is from lack of Freon. You can do damage to the system if you run it this way . Make sure the system is fully charged and check it for leaks . Hope this helps
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Little red さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 6
今までの合計 1,520
