メインコンテンツにスキップ
HPプリンターの修理ならびに解体ガイド
1090回答 すべてを表示
Should I refill the black?
Hello,
I got a HP officejet 4315 All-in-one printer which works fine but the 21 black is empty(checked under the label too)
And the reason i am unsure about refilling the black is the printer was from a garage of one of my neighbors who gave it to me
and it was in a box of thier daughters stuff possibly from college and was gonna be in the trash anyway and god knows how long its been there
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
7 件のコメント
I would not refill it--that's based on my experience from working on computers since 1960. YMMV
さんによる
rj - this IS the answer
さんによる
Why would you advise against refilling?
さんによる
It appears that both Ralph and I have had experience doing this with negative results.
さんによる
I tried to have walgreens refill it and
they told me it had a electrical failure
さんによる
2件以上のコメントを表示
コメントを追加
1 件の回答
ベストアンサー
having had various experiences from refilling cartridges ive learnt
some valuable lessons 1 is not to leave a cartridge empty for to long
the other is that ive found that you need to make sure the ink your using is compatible with your printer. remember if you going to try and refill your cartridge disposable gloves are a must and disposable kitchen towel don't over fill your cartridge and once installed back in the printer get it to do a head clean and print a test page you may need to do this several times but once the ink is flowing all will be well . So give it a go then you can post if it has worked or not .
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I oreded a 27 black which is better and cause i ewas told of how any probloems it had,i dont think i do and i dont know how long it was like this
さんによる
コメントを追加
回答を追加する
Nick さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 2
今までの合計 860
