メインコンテンツにスキップ
ユニボディMacBook Pro 13インチ Unibodyディスプレイモデルは2009年〜2012年に製造販売されました。
4630回答 すべてを表示
Shutdown on disconnecting power adapter, restarts on reconnection.
My MacBook Pro has been experiencing a number of strange issues. As soon as its disconnected from the power adapter it shuts down. I've tried cleaning the contacts and checking the pins.
The machine will then not restart, even though the battery read 99% at the tie of shutdown, until the power adapter is reconnected, at which point it will restart automatically. Usually, but not always, it will show the Prohibitory Symbol. This will flicker to the Apple logo and then the machine will boot and load normally.
The magsafe adapter is stuck on green.
I've tried resetting the NVRAM and SMC. This boot issue coincides with these logs from the last command.
reboot    ~                         Sun Jan  1 00:02
reboot    ~                         Thu May 18 17:31
reboot    ~                         Sun Jan  1 00:00
reboot    ~                         Thu May 18 17:11
reboot    ~                         Thu May 18 16:59
reboot    ~                         Thu May 18 16:45
reboot    ~                         Thu May 18 16:38
reboot    ~                         Thu May 18 14:04
reboot    ~                         Tue May 16 10:05
All reboots prior to this are on normal time.
Battery information is as follows (I know its a really high cycle count, could this be the issue?)
Model Information:
  Serial Number:    W0402ZAL4D3LC
  Manufacturer:    SMP
  Device Name:    bq20z451
  Pack Lot Code:    0
  PCB Lot Code:    0
  Firmware Version:    201
  Hardware Revision:    000a
  Cell Revision:    165
  Charge Information:
  Charge Remaining (mAh):    4176
  Fully Charged:    Yes
  Charging:    No
  Full Charge Capacity (mAh):    4219
  Health Information:
  Cycle Count:    1050
  Condition:    Replace Now
  Battery Installed:    Yes
  Amperage (mA):    0
  Voltage (mV):    12444
Any insight or tips much appreciated!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
It says your battery needs to be replaced. And it should be as it has over 1000 cycles.
You can confirm this using coconut battery
http://www.coconut-flavour.com/coconutba...
What model macbook pro do you have so i can find you the proper guide and battery for it?
MacBook Pro 13" Unibody Mid 2012のバッテリーの交換
How to replace it.
[リンクされた製品が存在しない、もしくは無効: IF163-019]
There is the part.
1050 cycles is a lot. Most of these are supposed to last max of 1000
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Thanks for the speedy answer. Would a defective battery go from holding 4/5 hours to dead overnight? Also, would that type of shutdown (sudden loss of power) lead to the prohibitory symbol? As it appears for a good 45 seconds even on restart without disconnecting the adapter.
MB is: MacBook Pro (13-inch, Mid 2012)
さんによる
yes they can. they can act weird sometimes.
さんによる
コメントを追加
回答を追加する
Jack Fuller さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 2
今までの合計 90
