メインコンテンツにスキップ
This is the Dell Latitude E5410 14.1" Essential (1st gen Core i3/i5/i7), which was released in 2012.
9回答 すべてを表示
Tracking pad and keyboard problem after spill of mineral water
Immediately after the spill, I turned off the laptop, turned it upside down and left it on paper towels overnight. I took out the battery. The laptop powers up, Windows7 loads. When I open Word, the keys appear to be stuck and the tracking pad does not work properly. Before I take it to the service shop, I would like to try to solve this myself, if I can. Thanks for any advice.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
It's quite possible that the keyboard is just dead, and could be replaced.
If I'm seeing it correctly, the touch pad may connect through the keyboard and chances are it's fine, but because the keyboard is damaged it's malfunctioning.
This guide hows the steps required to replace the keyboard.
Let me know if this helps.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
The keyboard connects through the palm rest, the palm rest contains the track pad. I think the problem is more in the palm rest than the keyboard although it could be both.
さんによる
コメントを追加
回答を追加する
E. U. さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 208
