メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
F01 error code troubleshooting
Washer had been sounding terrible during draining. And the quit running during random intervals during a cycle. Mostly right after the wash cycle. Cleaned filter, no success. Replaced the drain pump assuming it was the issue, had that problem before. Nope. Also changed the door lock switch thinking it was the safety mechanism preventing a spin cycle. Nope. Finally ran the diagnostic and figured out the F01 code. Checked my ccu for bulging capacitors or burnt out solder point. It looks good to me (though I'm not s professional). Any ideas before I go dropping money on a new ccu? I read somewhere I might have a timer issue?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
@dgadoci, Drew , Before dropping money on a new CCU, Unplug machine and go over all connections, unplugging connectors checking for corrosion/burn/damage/loose wires, clean if required and reconnect making sure connection secure/tight. Service manual below may help. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Duet-Aid_also-Kenmore-HE3.pdf
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Drew さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 6
今までの合計 1,062
