メインコンテンツにスキップ
The third generation of the Samsung Galaxy tablet with a 7-in. screen announced on June 24, 2013. Repair of this device requires screwdrivers and prying tools. The device is available in white or gold brown with 8, 16, or 32 GB of storage, and includes a microSD slot that can hold up to an additional 64 GB of memory.
120回答 すべてを表示
forgot my pin number
how can I bypass lost pin number
Update (05/10/2017)
I have a Samsung galaxy note 3 model number is sm-t210 can I get in without loosing everything by doing a factory reset ????
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 19
11 件のコメント
Look at what i posted. I have multiple options on how to do it.
さんによる
How to unlock a pin code from screen
さんによる
i forgot my 4 digit pin to my samsung galaxy tab how can i know what is the password
さんによる
How can I unlock my Samsung Galaxy tablet for my pin number
さんによる
I forgot my 4-Digit pin to my Galaxy tablet how can I recover that without hard booting it and losing all my information
さんによる
6件以上のコメントを表示
コメントを追加
7件の回答
最も参考になった回答
https://android.gadgethacks.com/how-to/7...
There are a few different ways that do not involve data loss.
I hope this helps! If it did please hit accept answer!
このアンサーは役に立ちましたか?
スコア 6
コメントを追加
The only way to bypass the unlock code is to factory reset your tablet, you will loose all your data though.
1. Power off your device.
2. Boot in recovery mode by pressing and holding Volume Up, Power Button and Home Button at the same time.
3. Release all buttons when the Samsung Galaxy Tab 3 Lite 7.0 screen flickers and in a few seconds the Recovery screen will appear.
A menu will appear use the volume up/down buttons to navigate to Factory Reset option and press the power button to accept, select OK/YES from the menu the proceeds to Factory Reset your tablet
このアンサーは役に立ちましたか?
スコア 4
3 件のコメント:
yes its very helpful for me
さんによる
I cannot switch the tablet off without the pin number?
さんによる
Not helpful because it doesn't work on every tablet I did all this and the pin is still there
さんによる
コメントを追加
I was able to fix mine using the pin # 1234.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
It says draw of directions to unlock screen
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
What I want to do is to unlock my Samsung Galaxy Tab
さんによる
The tap says draw series of directions to unlock screen
さんによる
コメントを追加
More than a year now
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
What does score 0 mean?
さんによる
Am failing to understand score 0
さんによる
コメントを追加
Hey Luke you need to do a hard reset this may not work but try power off then push volume up and power button for about 4 sec. if it trys to power back on go 3 sec. what you want to do is get the robot on there and volume buttons up and down will guide you to reset enter will be power button good luck
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Somebody gave this tablet the The Samsung Galaxy tablet 3 but the person does not remember the PIN number so how can I get in it to break the PIN number so I can open up the tablet
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
How can I get into Samsung Galaxy tablet 3 when the person that gave it to my son doesn't remember the pin number which is a four number code how can I get into it to open it up and it won't allow me to do nothing
さんによる
コメントを追加
回答を追加する
Luke Matthews さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 13
過去 30 日: 49
今までの合計 47,434
