メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2014年7月28日に発売されたSamsung Galaxy S5 miniは、800万画素のリアカメラ、720pディスプレイ、指紋センサー、耐水性を備えた携帯電話です。兄弟機であるGalaxy S5と比較して、ディスプレイの大型化、バッテリー駆動時間の延長、カメラのアップデートが行われています。
Microphone doesn't work very well when using speaker
Hi there! Sometimes when I send voice notes in WhatsApp my friends cant hear whatever I say, I thought that it was WhatsApp's problem until I made a call with the default phone app and turned on the speaker, whenever I speak 'normally', the microphone works correctly but when I use speaker, WhatsApp, Skype or similar apps (even in-game) the mic doesn't work
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
it uses a secondary microphone located at the top.. did you changed lcd?
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
No, I haven't but thanks for the info, I'm going to check if it is broken or anything, is there any other possible reason why it is not working?
さんによる 共有
dirty.. open it clean it. it will work. they just don't go dead..(maybe but not really).. if u need pics let me know. ill tell u how to,
さんによる 共有
Lol I got robbed the next day after I posted that comment. I found that this is a common problem, my friend's phone had the same problem so I tried buying a new mic and it didn't work so I decided to replace the whole display with the mic and speaker and it worked perfectly.
さんによる 共有
コメントを追加
What if the LCD has changed ? Does it affect the microphone, I bought this phone used so IDK what's replaced in it.
I opened it up and cleaned the mic ports now the bottom works well but the top is too weak.. and why does my phone switch to the top mic in loud speaker mode ?
Thanks
(Galaxy S4)
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Loud speaker mode uses sencondary microphone, in ur case is slow bc the hole might have adhesive... open it up clean the adhesive and with the screw driver poke a biger hole.. that will fix ur problem with low secondary mic.. if the lcd is new... if is and old lcd its just dirty , try changing that mesh completely... best of lucks.
さんによる 共有
コメントを追加
回答を追加する
rickyestrella95 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 18
今までの合計 1,107
