メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
AcerのWindows搭載ノートパソコンシリーズ、Acer Aspire V5の修理ガイドとトラブルシューティング。
BIOS password Hard reset
Please how do I hard reset the BIOS password? Help me
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 7
2 件のコメント:
bios pasword acer aspire v5 431 series
さんによる 共有
O do need to reset it but it won’t let me in at all , so what I need is to get to a blank and set it from cero , is that posible ?
さんによる 共有
コメントを追加
3件の回答
https://www.youtube.com/watch?v=UKv5v24a...
When you open the bottom, you will see a small silver circle. Remove it and leave it out for 20 or 30 minutes and then put it back. Make sure the laptop isnt plugged in and the battery is also unplugged for this process.
After that time, put the silver battery back, plug the main battery back in and then try. If it doesnt work, try again and make sure everything is unplugged.
Hope this helps! If it did please hit the accept answer button!
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
@cam2363, if this is a modern laptop, that may not work any longer.
さんによる 共有
Well, its still worth a shot. The bios password isnt really secure. Its worth a shot, if not then we will search for other options.
さんによる 共有
I just wanted to confirm this tried and true method does not work on this model, at least specifically on a V5-122p, left battery out for 24 hours. No CLR CMOS jumpers that are clearly indicated either, plenty of contact pads to short for the adventurous though. Hint: JOKING, DON'T start shorting contact points on your mainboard, unless you wish death upon it.
Bummer about the easy clearing methods though, if ours wasn't stuck in UEFI, we could have run a BIOS flash or password cleaner in DOS.
さんによる 共有
and for bios password reset model acer aspire v5 121....what can i do ?
さんによる 共有
コメントを追加
  • i am jus a happy nigga, hoden down da crib wit my homie D.J. Austee Pinz
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If you want to learn how to start a Blog www.petteen.com/, I suggest you read the full tutorial. If you want to know how to create a shopify site www.petteen.com/creation-dun-site-shopify/, click on this link, or how to publish a book on amazon : https://www.petteen.com/comment-publier-..., and https://www.africanproof.com
For productivity: www.pomodoro-timers.com/app/, or to know the height of your preferred celebrity: www.quelletaille.fr
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Lapia さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 31
今までの合計 13,496
