メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2690回答 すべてを表示
Screen connectors don't fit
Hey can someone help me please?! I bought an iphone 6s replacement screen for my iphone 6s because the screen is broken... And I just switched all the parts from the old screen onto the new one! And as Im about to put the 4 conectors back in well they dont fit?! Can anyone help me please?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
If it has 4 connectors as you say you got the iPhone 6 screen replacement. The 6s only has 3 connectors.
さんによる
I had the same problem and it has nothing to do with after market parts. When you switched the camera assembly to the new case, you put that cable under the other cables, reversing the order. Remove the shield, and place the camera cable on top of the 2 larger board cables and all will fit properly
さんによる
コメントを追加
6件の回答
ベストアンサー
First, you should probably verify the model of your phone and make sure you've got the right part. I'm pretty sure a fully assembled iPhone 6s display should have three connectors, not four.
Next, compare the new display with the old display. Are they identical? Are the connectors physically different? Sometimes the display ribbon cables get folded in the wrong order so they won't line up properly, and in that case it's a simple matter of carefully reorganizing the cables so they line up with their sockets.
Let us know what you find and maybe we can help further. Good luck!
このアンサーは役に立ちましたか?
スコア 5
2 件のコメント:
Hey! Thanks for the reply. I bought an Iphone off someone and they said it was an Iphone 6s and I believe them and I ordered and Iphone 6s Screen.. My phone is actually an iphone 6. I ordered a Iphone 6 screen and it has all turned out well! Thanks mate.
さんによる
No....ordered 2nd in a row replacement screen (for two different phones) Both have 2 ribbons with 2 connectors....I am removing iPhone screen with 3 connectors....what is going on? What is missing
さんによる
コメントを追加
This happens with aftermarket displays. The connector socket cables won't fit in the connector sockets. Or the stupid foam sticker on the cable is misaligned, and it deeks me out, can't get em on properly. I do agree with @jeffsu lets make sure you got the right part. Also when you put the connector cables on, push down on the side, not middle, then the other side
このアンサーは役に立ちましたか?
スコア 5
1件のコメント:
No! I just went to replace my second iPhone screen, both correct screens ordered...BOTH MISSING CONNECTOR....HAVE 2 BUT SCREEN BEING REPLACED HAS 3!!! WTF?
さんによる
コメントを追加
I think i ran into the same problem the iPhone 6s plus has touch button cable built into digitizer the iphone 6 plus has it in the metal that covers digitizer . Live and Learn.
Correct me if im wrong. Haven't been able to verify. But reordered made sure model # for my phone was listed. All is well.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I bought a new screen for my iPhone 6, and it says on the package it’s for iPhone 6, and it all fit, and I transferred the parts over to the new screen. But the middle connector to plug the screen in won’t plug in. The home button connector and the other two will connect just fine, but the middle one won’t connect. Any ideas?
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
That just happened me, in case you didn’t figure it out You need to remove the metal back cover and readjust the cable attached to tha metal cover. This actually slots in the middle of the 2 main cables on the new screen. I think I fkd my main board as I tried starting it up knowing that they didn’t sit properly.
さんによる
Hey I kinda have the same problem but I don’t get what you mean by removing the metal back cover. You’re not talking about the cover of the screen cable right?
さんによる
I think he means the metal bracket covering the connecters I've replaced screen and ribblle cables for the screen were two long and had to fold them a little witch prevent me from putting the metal bracket back on over connecters
さんによる
コメントを追加
Can an iPhone 6s with two connectors work on an iPhone 6s with three slots?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
iPhone 6s should have two horizontal connectors one for display and the other for front camera then the vertical one which is used for connecting the home button.
If you only see two connectors on the replacement screen that is correct for the 6S as it just means the front camera isn't installed yet which can be transferred from the old screen.
Always remember to disconnect battery before screen replacement :) Hopefully the repair repair goes well.
さんによる
コメントを追加
Which one is the home button connector please as mine doesn’t seem to be working?
is it one of the 2 larger connectors, or the very small one please?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
If you have a photo, that would be very much appreciated
さんによる
コメントを追加
回答を追加する
Kaya Rezende さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 13
過去 30 日: 42
今までの合計 25,157
