Why is the back camera taking blurry pictures?
The back camera on my phone works but takes blurry photos. The front camera works without a problem. Why is that? Thanks.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The problem could simply be that the camera is not in focus. When taking a picture, tap the area on the screen you would like to focus on. The lens on the camera may be dirty so cleaning that would reduce blurriness. The camera itself may also be damaged and need replacement. For more information, check out the troubleshooting page for more detail and information about replacing the camera.
このアンサーは役に立ちましたか?
What liquid is the best to clean dirts from the camera with blurry results?
My problem solved.Alhamdulillah
My camera got blur after changed with new battery.
Then I ask back the shop to clean the camera and he just used cutton bud to clean the camera.
Now the camera back to normal.
このアンサーは役に立ちましたか?
Is there water or steam under the camera? Silly but have you tried cleaning it? Try turning options off like filters and autofocus.
このアンサーは役に立ちましたか?
How can you get under the glass to clean the mist
I can see it's missed up
https://howtofixphone.com/xiaomi-mi-11-c... This will help you.
Change the back casing
このアンサーは役に立ちましたか?
My phone redmi 6a is showing the pic as black when took in manual focus mode
A solution that works for sure!
Search for Google Camera for your EXACT MODEL!!!
There is some custom mods for this app that works perfectly and does all you need plus more like night mode,and the autofocus is perfect,the image noise no longer appears,and so on!
I can't provide links for all models and test them to see if works ,for my phone I downloaded like 4-5 apps to get it working but ones it's done you're not gonna regret it!
このアンサーは役に立ちましたか?
I have used Redmi Note 7 and Mi 9t, both are Xiaomi products.
Observation:
At first the back camera photos are very clear and beautiful but after about 3 months of using the phones, the camera photos become so dark and blurry.
I have downloaded other camera apps to use on both. When the camera is on display to capture the picture, you would see the picture so clear but once you take the shot, the picture would become dark and blurry.
Those of you who haven't used your phones for more than 4months should not counter this please
What is wrong with Xiaomi phones camera?
Xiaomi
Same problem in redmi k20 pro
Problem us in hardware , not I software . I have two redmi mobiles. Both's rear cam taking blurry and dark pics , tried all options but none worked , then got my mobiles to Repairing shop, they opened it , checked it , they said CAMERA IS FINISHED, SENSOR FINISHED . NO REPAIR OR REPLACEMENT.
that's it .
If happens with thousands of redmi mobiles .
Exactly same problem with me, service centre is telling to exchange motherboard of rs 14500 , my phone is new but still facing same problem. I m going to take legal action on MI
All of u guys, please flash the old version of rom, like miui 10, problem will be solved, i try and working
このアンサーは役に立ちましたか?
I'm not sure one day my back camera capture the small images very clearly another day same image appear as blurr.. It happens day after day
このアンサーは役に立ちましたか?
Besides a hardware/firmware/Operative system/software problem: Try to use the naked camera without any case or cover (remember to keep tight the battery or it will drop when placing the phone vertically). I found that the problem got solved and that camera is properly working.
Now I must find a way to solve how these extra layers affect focus, which seems far easier…
このアンサーは役に立ちましたか?
I tried everything, even replaced the camera and still blurry, it’s like it doesn’t even try to focus
このアンサーは役に立ちましたか?
Xiaomi is becoming like a scam to me with their very poor camera
過去 24時間: 12
過去 7 日: 67
過去 30 日: 302
今までの合計 99,587
14 件のコメント
Same issue am facing from last 10days.am unhappy with mi note 5 pro back camera... It's been one month I have purchased mi note 5pro from flipkart big billion sale.. What should I do to fix this issue
Vishal さんによる
Had the same problem. Removed lens protector (which I applied when I bought the phone), cleaned the lens. That did it for me.
G.J. van Mulbregt さんによる
I am also facing same problem in Note 10 pro. Even gpay and other upi app not scanned UPI QR
Nikhil Vyas さんによる
I am getting blurred image from the front camera for my Xiaomi note 11i
Sanjay Joshi さんによる
I have the same problem. When i bought my phonebthe camera is okay but after like 2 weeks back camera became blurry. You can see little dots. by the way i just bought this phone 1 my month later
Deym Diyem さんによる
9件以上のコメントを表示
