メインコンテンツにスキップ
Device and repair guides for the 2016 Samsung Galaxy J5 Prime smartphone, model number SM-G570Y or G570.
79回答 すべてを表示
J5 Prime Phone will not turn on
So I've had a Samsung J5 Prime for just over 5 months now, and this is the first time it's ever acted up. I didn't charge it over the night, (I forgot) but charged it when i woke up and it was around 60% before I went to school. After about 4 hours of working fine, I went to check the time and my phone wouldn't turn on at all. Held down the power button etc and naturally assumed it had run out of battery. I remember it had about 40% charge left which I thought was a little strange, but I came home and plugged it in.
I've left it charging for about an hour and a half now, but nothing has happened, no red light, no response.
Yes, I checked if the charger was turned on.
I've tried holding down the power button while it's charging
I've tried switching power plugs and chargers
No idea what to do......
Also, the back cover doesn't come off so i cant take out the battery etc.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 32
31 件のコメント
awesome!!!!!!!!!!!
さんによる
My phone doesn't turn on but the battery/charging indicator is red I've put it on charge for hours now.I've tried soft reboot solution but didn't work.help pls.
さんによる
I've had this problem just a few moments ago. I got the correct answer from one of the comments. Thank you very much for posting the answer.
さんによる
SamSuung J5 Prime is a working time bomb.... Another error!!! While watching a movie, my J5 Prime makes a sound like a lose fan very loud and it hooks and the phone stopped working this is the 2nd time in 2days...
さんによる
Hey my Samsung turns on but it wont show the menu .....it turns on but stucks at the sign SAMSUNG
さんによる
26件以上のコメントを表示
コメントを追加
2件の回答
ベストアンサー
Hi Liz,
You're probably solved this by now - but I just had the same issue. Nothing else I tried worked before this:
I pressed Volume Down + Home Button + Power Button for a few seconds.
After a few seconds I got a turquise screen warning me about a custom OS install.
I cancelled that with a Volume Down press and then my phone booted normally.
Got the idea from here.
Hope that helps Liz (and you future Internet person),
Z:D
このアンサーは役に立ちましたか?
スコア 184
99 件のコメント:
Thanks so much for helping out!
You're right - I did end up solving it on my own but thank you anyways
Holding down the home and power button at the same time works as well, (it's called a soft reboot, same as taking battery out on another samsung) that's how mine turned on.
さんによる
this is awesome!! thanks for the great tip! i thought i had to go down to the customer service centre to get the set replaced.
さんによる
my screen is blinking and thats why
i cant rebbot my phone
さんによる
Thank you so much. it helped me a lot after i faced this problem for the first time..:)
さんによる
THANKS a lot dear it works no need to go to repair shop..
さんによる
94件以上のコメントを表示
コメントを追加
Charge with original samsung power addapter and cable.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
omg thank you so much!
さんによる
コメントを追加
回答を追加する
Liz さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 25
過去 30 日: 71
今までの合計 119,941
