How to remove and replace cracked screen on HP Probook 645?
I have an HP Probook 645 with a cracked screen. How do I remove it and replace the screen so that the unit will function again?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @j89racer,
Here is a link to the service manual for your laptop.
Scroll to p.82 to view the necessary pre-requisite steps and then the procedure to remove the display panel.
Also on p.82 you will find the part numbers for the various panels available, (the part number of your panel should be stamped on the back of the panel itself).
Once you have determined the correct part number for your panel, search online using the part number only to find suppliers of the part that suits you best.
Hopefully this is of some help.
このアンサーは役に立ちましたか?
https://www.youtube.com/watch?v=Ja_eyAXM...
Thats a guide on how to remove it.
If this answered your question, please hit the accept answer button!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 640
