Hard Drive not Detected after upgrading to SSD
I upgraded to a SSD after my stock hard drive failed. After running diagnostics, all hardware works but no HDD is detected at BIOS. Tried reseating it and still no luck. Upgraded to Corsair 120gb SATA 3 SDD.
Dells website and phone service both were unable to answer if my device would accept HDD to SSD replacement.
Update (04/25/2017)
Thank you for your quick response Dan. This SSD is backwards compatible so there is still something awry.
My system would boot to desktop (with windows on usb) and could not complete windows download with a storage space issue. Knowing I had the space that was the first I noticed that there was no HDD being recognized- now I only get as far as setting language pref and cannot reach the desktop. Does this raise any flags?
この質問は役に立ちましたか?
4 件のコメント
Your systems specs: Dell Inspiron 3451 & 3458 specs
Dan さんによる
The only other possibility is the drives SATA cable is bad.
Can you tell us what SSD you're using here (Make & Model)?
Dan さんによる
The SSD is a Corsair Force Series 120gb SATA 3. Thanks again for your input.
Spath024 さんによる
Your SSD's specs: Corsair Force 120GB SATA 3 6Gb/s SSD
Dan さんによる
