メインコンテンツにスキップ
The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
113回答 すべてを表示
Low fuel warning stays on
Fuel low warning lit up with 3/4 full tank. I filled the tank, the light stayed on. I removed the sender and disassembled it and cleaned it. I got a little bit of the black crap out of it but nothing that could bridge the contacts at the bottom. I put it back together and the light stay's on. Bummer. The fuel gage seems to be accurate, the 3 wires are good.
Anyone know where I should look next?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
選択されたソリューション
@old_pat ,Pat, link below had similar issue and stated they had to add additional ground to back side of gage cluster. See link below for more info and pic's. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.benzworld.org/forums/r-c107-s...
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Pat Sweeney さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 27
今までの合計 1,463
