メインコンテンツにスキップ
PSP 3000は、2008年10月15日に米国で発売されました。このデバイスの修理には一般的なツールのみが必要です。
PSP not working after using it with a faulty cable
Hi, I have a PSP without a battery and was playing on it by having it plugged into a powerbank constantly. After some time, the psp started turning off when the cable was at a certain angle. It didnt happen very often, so I just ignored it, but after a while the psp stopped turning on, not even the green light would turn on. I thought the cable has shortcircuited inside, and so I checked 2 fuses on the motherboard with a multimeter, but they seemed to be fine.
Any help would be appriciated, thanks.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Martin Sevela this "turning off when the cable was at a certain angle" sounds like your issue is with the power connector. To replace it or to check it, you'd have to remove the motherboard. Use this guide to get there. The connector would have to be replaced by soldering a new one to the board. that would also give you an opportunity to replace the battery.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Martin Sevela さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 9
今までの合計 227
